Hello all,i have a Roper washer model number RAX7245KQO its just over 10 years old.It goes through the wash cycle ok,but just before it drains and/or spins it stops completely.I thought this info might help you guys with my issue.If i lift the lid and have the washer knob turned out/on i can hold down the lid switch and it will start spinning and draining,but as soon as i close the lid it will stop.I've searched the videos here which are very helpful,i believe i could change the lid switch,but do you guys think that sounds like my issue?I'm ok with trying that,but unsure if it could be motor or clutch/transmission related,as i've never attempted working on a washer before.Thanks to anyone who could chime in with their opinion,i appreciate it ! Jeff.
This is almost certainly the lid switch, and it is a repair you can do. Just take your time Here is the part Part number: AP3100003
and the video will show you how to do this Good luck, you'll be fine.
Replaced the lid switch,i had trouble getting the body back on the frame of all things,i tried to do it like in the video,but its wobbly and just doesnt want to go back on right.I might try to get some help with this sometime.But anyway,its working normal again,so thanks for the help !
Yes it is difficult sometimes getting the cabinet back on. I tilt it from the front, and open the lid to see that the front lip goes like it should.
Glad you got it fixed, good luck with your washer!
