Little old me
#1 Posted : Saturday, January 28, 2012 4:22:51 PM(UTC)
Little old me
Hello, my Kenmore washing machine 110.26962500 will no longer spin the load at the end of the cycle. If I take the washer basket and rotate it it's very loose, and then will lock down tight and will occasionally start to spin. Sometimes I have to do this multiple times to get it to lock and stay engaged to spin the load. Does this sound like a transmission to you? Everything else works well on the washing machine. Thanks for your help!!
sidfink43
#2 Posted : Monday, January 30, 2012 5:13:41 PM(UTC)
sidfink43
This sounds more like a clutch or brakes problem. Read the sticky at the top of the Washer Forum page by Richappy on direct drive brakes and use the video library
http://forum.appliancepartspros...asher-repair-videos.html
to find the video that will show you how to open it up and replace the clutch.
Kenmore washer won't spin (Washer Repair)
by KENSAR 9/8/2014 7:17:44 PM(UTC)
by gorogergo 8/23/2014 12:33:47 PM(UTC)
Kenmore Washer won't spin at all (Washer Repair)
by Mealbee 6/29/2014 1:01:14 PM(UTC)
Kenmore Washer Won't spin (Washer Repair)
by CrossWashappliances 2/2/2014 5:10:05 AM(UTC)
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 1/23/2014 6:22:22 PM(UTC)
Kenmore Washer Won't Spin, Drain Properly (Washer Repair)
by TheDude 12/30/2013 11:53:55 PM(UTC)
90 series kenmore washer won't spin, drain (Washer Repair)
by Beckmd 10/25/2013 3:14:26 PM(UTC)
Kenmore washer won't spin, stop agitating, or drain. HELP! (Washer Repair)
by bwal314 7/15/2013 7:00:50 AM(UTC)
by tbditw 2/3/2013 4:52:34 PM(UTC)
Kenmore Washer won't spin (Washer Repair)
by Electechab 1/29/2013 3:43:56 PM(UTC)
Kenmore washer won't spin correctly at times (Washer Repair)
by phillips1978 6/19/2012 6:46:04 AM(UTC)
Kenmore Washer won't spin, agitate or drain (Washer Repair)
by Micky_577 5/14/2012 9:28:00 AM(UTC)
Kenmore washer won't spinj (Washer Repair)
by duckhunter22 3/10/2012 7:23:13 AM(UTC)
by dmw1209 1/2/2012 7:12:26 PM(UTC)
by pgarbs 9/1/2011 10:19:22 AM(UTC)
