Discuss
Frigidaire front load washer will not spin
 in
Washer Repair
My 2 year old front load washer stopped doing the high speed spin a couple of days ago. It goes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire front load washer will not spin
  #1 (permalink)
Old 01-03-2008, 09:45 AM
Junior Member
Merlis is on a distinguished road
Default Frigidaire front load washer will not spin
Model Number: FTF2140ES0   Brand: Frigidaire   Age: 1 - 5 years
My 2 year old front load washer stopped doing the high speed spin a couple of days ago. It goes through all the motions, but when it comes to the final spin/drain cycle, it will only drain.
I made sure all doors were closed, tried to wash several different loads to make sure that it wasn't an unbalanced load or too light/heavy. Still no luck.
I found the tech data sheet inside the machine, followed the instructions, and brought up the error code E43 (control board problem/replace board). I replaced the board and it still won't spin. New board still shows E43.
I next ran through the diagnostic test. All the functions worked including the high speed spin and door lock test. I also checked the drain boot and it wasn't clogged.
Why does the high speed spin work in the diagnostic mode, but won't work on any wash cycles? What's wrong with this thing? I don't want to manually make it spin every wash load. Please help, getting frustrated!
Ads By Google
Related Models
Frigidaire FTF2140ES0 Frigidaire/washer
Frigidaire FTF2140ES1 Frigidaire/washer
Frigidaire FTF2140ES2 Frigidaire/washer
Frigidaire FTF2140ES3 Frigidaire/washer
Frigidaire FTF2140FS0 Frigidaire/washer
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU054ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU100JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW5 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU134ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU134ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU134JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134JRW4 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU161ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU161ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU161ERW5 Wwh(v5) / Upright Freezer
Frigidaire FU161ERW6 Wwh(v6) / Upright Freezer
Frigidaire FU161JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW2 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU161LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU161LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU166ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU166ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU166ERW3 Wwh(v9) / Upright Freezer
Frigidaire FU166ERW4 Wwh(v10) / Upright Freezer
Frigidaire FU166HRD1 Wwh(v1) / Upright Freezer
Frigidaire FU166HRD2 Wwh(v2) / Upright Freezer
Frigidaire FU166HRW1 Wwh(v3) / Upright Freezer
Frigidaire FU166HRW2 Wwh(v4) / Upright Freezer
Frigidaire FU166HRW3 Wwh(v5) / Upright Freezer
Frigidaire FU168JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU168JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU168JRD3 Wwh(v1) / Upright Freezer
Frigidaire FU168JRW1 Wwh(v3) / Upright Freezer
Frigidaire FU168JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU168JRW3 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW2 Wwh(v4) / Upright Freezer
Frigidaire FU169ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU169ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU169ERW1 Wwh(v3) / Upright Freezer
Frigidaire FU169ERW2 Wwh(v4) / Upright Freezer
Frigidaire FU169JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU169JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU169JRD3 Wwh(v4) / Upright Freezer
Frigidaire FU169JRW1 Wwh(v2) / Upright Freezer
Frigidaire FU169JRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW3 Wwh(v2) / Upright Freezer
Frigidaire FU169LRW4 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU196ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU196JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU196JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU196JRW3 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU196LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU196LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU199ERD1 Wwh(v5) / Upright Freezer
Frigidaire FU199ERD2 Wwh(v6) / Upright Freezer
Frigidaire FU199ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU199ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU199JRD1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRD2 Wwh(v1) / Upright Freezer
Frigidaire FU199JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU199JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU199LRW2 Wwh(v3) / Upright Freezer
Frigidaire FU199LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW5 Wwh(v1) / Upright Freezer
  #2 (permalink)
Old 01-03-2008, 08:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Which control board did you replace?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-03-2008, 08:30 PM
Junior Member
Default
I replaced the main control board (Part # 134484018 - control board, printed circuit, with housing). I now see that there is another part called the motor control board sa well. But if the motor control board is faulty, why does the machine do a high speed spin in the diagnostic mode? Wouldn't the high speed spin not work if this part was defective?
  #4 (permalink)
Old 01-04-2008, 03:45 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
On your service sheet there is a chain diagram for no spin problems. It includes the door switch, the soap dispenser reed switch and the timer. Probably a bad door switch. There is an easy test for this.
Remove front panel and locate the test connector near the door switch. Stick your voltmeter leads in this, should not be any voltage during spin. Voltage=bad door switch.
If no connector, you will need to pull the door switch to check. I usually remove the right side of the boot to facilitate door switch removal. Get some super glue to re-attach boot.
__________________
  #5 (permalink)
Old 01-04-2008, 04:13 PM
Junior Member
Default
I don't think I have the information on my spec sheet that you mentioned. The new control board I installed came with a note saying "Testing has shown the reed switch is not needed on front load washers. If the washer has a reed switch, disconnect it from the old board and discard." The new control board doesn't even have the terminals to connect the reed switch. I don't think that's the problem.
I can't find any sort of test connector behind the front panel, so I removed the switch. I showed an electrician the schematic for the washer, and he told me to test the gray and red wire terminals of the door switch for 1325 ohms of resistance. I think I found the one he meant, it was a red with black stripe wire. It tested at 1389 (okay I think?). I also tested the gray and black wires for voltage and found 120 volts with the machine in standby, and 0 volts during spin cycle. Is this right? I'm not sure if I'm testing the right terminals or not. Any help with exactly which wires to test would be very appreciated.
The door switch has three different connectors going to it. One has two wires, pink and red with black stripe. I believe this connects to the wax something. The next connector has four, an orange wire and three red with black stripe wires. The last connector has two, a black and a gray wire. Too many red with black, I am very confused.
I can hear the door lock when I go through the diagnostic tests and make the washer spin that way, but I don't know if that means anything or not. Any help with which wires/terminals to test would be great.
  #6 (permalink)
Old 01-05-2008, 02:14 AM
Senior Expert
APP Volunteer
Default
I have little experience on this washer,maybe someone else can help. The only advice I can give is check all the connectors, sometimes pins come loose.Everything else you have already replaced or tested ok.
__________________
  #7 (permalink)
Old 01-05-2008, 02:32 AM
Senior Expert
APP Volunteer
Default
You can call this parts site and order the repair manual, $19 or just order the door switch and speed control board. If either one fixes your problem, you can send the other one back, they have a good return policy.
__________________
  #8 (permalink)
Old 12-23-2008, 12:02 PM
Junior Member
Jim Engel is on a distinguished road
Default
I have the same problem as you except my code is E47 Board thinks door latch circuit is open. Did you ever find a solution?
  #9 (permalink)
Old 12-23-2008, 09:24 PM
Junior Member
Default
Quote:
I eventually gave up trying to fix it myself and called an appliance repairman. As it turned out, the problem was a faulty door lock. Needless to say, I wasn't very happy. What's the point in displaying error codes if they are the wrong ones. The door lock test didn't help me diagnose the problem either, it seemed to lock/unlock just fine. Anyhow, I don't know how helpful I've been, I would suggest replacing the door lock and seeing what that does first since it is fairly inexpensive (not like the stupid control board that I wasn't able to return!) Good Luck!
  #10 (permalink)
Old 12-29-2008, 09:00 AM
Junior Member
Default
Thanks Your experience is helpful even though costly to you it gives me more information on which to make a decision. I'd rather learn by some one else's mistakes. I called a service person to get an estimate for a visit. I told him the code i got #47 he said that often doesn't mean anything. he said he would replace the door lock first so that is what i will try . Another person had a similar problem replaced the door lock which didn't help and then had to replace the control board.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire front load washer will not spin only tumbles FILTTY Washer Repair 1 02-14-2010 06:53 AM
frigidaire front load washer will not go into final spin cubbie23 Washer Repair 2 02-12-2010 12:40 PM
Front load Frigidaire won't spin at all Gangster Washer Repair 2 12-13-2008 07:33 AM
Frigidaire front load washer won't spin jociadam Washer Repair 1 07-03-2008 06:52 AM
Frigidaire Front Load Washer Won't Spin bbemis Washer Repair 2 11-28-2007 07:46 AM
