ALAN LEVENS
#1 Posted : Monday, December 5, 2011 12:29:56 PM(UTC)
ALAN LEVENS
When you start the cycle is stops at 21 or 22 and displays "F". Then the unit will not start.
ApplianceJunk
#2 Posted : Monday, December 5, 2011 1:05:19 PM(UTC)
ApplianceJunk
Hi Alan
It does this right at the start of the cycle then before it's full of water?
F21 22 error code is
CCU/TOUCH-PAD/LED ASSEMBLY ERROR
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Here is a copy of the tech sheet with some more information, maybe it will help.
File Attachment(s):
Tech Sheet - 8182208.pdf (163kb) downloaded 61 time(s).
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Samsung Error Code (Oven Repair (including Ranges and Cooktops))
by Guest 11/6/2023 12:46:38 PM(UTC)
Kenmore OL Error Code (Washer Repair)
by Guest 10/27/2023 8:37:16 PM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Kenmore Elite F09 error code (Washer Repair)
by dieselgg 10/19/2023 4:01:12 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Error code SY EF (Refrigerator & Freezer Repair)
by Guest 7/17/2023 1:05:46 PM(UTC)
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
KitchenAid Error Code 6-1 (Dishwasher Repair)
by JBishop 4/7/2023 12:37:12 PM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
LG LMXS30776S/03 refer error code F1 (Refrigerator & Freezer Repair)
by FishinBob 12/9/2022 8:36:17 AM(UTC)
