Please Help! :confused: I have an Amana top load model NAV8805EWW washer. We lost power Friday night and Saturday morning it did not work. The machine starts filling and within 1 minute shuts down and all the lights flash twice and the only light that is on is the normal wash. Here is what I have done. I have checked the main water valve and it operates fine. I have run this on the spin only and it drains and spins with no problems. I have tried every switch and it operates for just a moment. I also disconnected the air tube to the fill switch and started the machine and blew into the air hole and the machine went directly to agitate and instantly shut down. I am thinking it is the control board......any Ideas would be appreciated! ;) Please send any info to tmfallon@derrickcorp.com Tom
