I have a top loading Kenmore washer that has suddenly stopped spinning. It will agitate the clothes. I have checked the switch that stops the spinning when the lid is opened, but that is fine. Any ideas?:(
It does drain, but I just found out that it won't spin or agitate. Makes noise when you put it in spin, like it's trying to do something.
It' pretty likely to be a broken motor coupling. It's a very easy fix that can save you about $100, if you do it yourself. Part number: AP3963893
