vito
#1 Posted : Saturday, February 21, 2009 5:23:41 PM(UTC)
vito
Spin cycle just stopped. Replaced control panel w/ circut board & still, no change. Checked the door & soap drawer & drain hose. I went through all cycles and it washes fine w/ barrel movement. The drain pump is louder than normal, but still pumps water and hose is clear. Could the pump have worn out impellers and not send a signal that starts spin cycle ? What next ? Please Help, my wife is giong nuts ! I can't get anyone to come out untill next week.
TechnicianBrian
#2 Posted : Saturday, February 21, 2009 7:37:51 PM(UTC)
TechnicianBrian
Can you check your model number please. I am guessing you have a Frigidaire built front loader, but the model isn't is a normal Kenmore format. If the washer washes but never spins, I may have a solution for you.
vito
#3 Posted : Sunday, February 22, 2009 8:19:47 AM(UTC)
vito
The model # on inside front door is 417.44092500 & Yes it looks the same as a Frigidire. Thanks for your reply.
TechnicianBrian
#4 Posted : Sunday, February 22, 2009 8:32:55 AM(UTC)
TechnicianBrian
If you find the unit washes, but just never gets up to full spin speed, the door lock is probably the cause. I wrote about this problem in a post Frigidaire Washer Won't Spin on my blog. Give it a look and see if this sounds like your problem.
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
