2 Pages12>
Guest
#1 Posted : Tuesday, January 31, 2023 12:30:04 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
i have a whirlpool washer model lsc8244bq0 that is messing up bad. recently the agitator started working on almost every cycle. i have check the motor coupling and they look great, when i start the washer everything works perfect it fill it agitates and spin drains the water then repeats process but once its done with wash cycle and move into the cool down phase the agitator will not disengage and wants to agitate on every time the washer drains and spins the clothes causing the clothes to get tightly wrapped around agitator bringing machine to stop. from my understanding and from what ive read it could be the transmission, clutch, starter capacitor or im not sure. the thing that's stumping me is the first 2 fill and drain for wash cycle work great. no problems but after that it goes down hill fast. last time i ran the machine the spin cycle worked great but the next load of clothes the agitator started working when it wasn't suppose to work. here are some short videos on youtube of the problems and how sometimes the spin works and doesn't work due to agitator. also video of agitator working perfectly fine.
ThatGuy
#2 Posted : Tuesday, January 31, 2023 4:43:47 PM(UTC)
ThatGuy
Groups: Expert
United States
The problem you are describing is inside the transmission. Most likely its this part that's causing the problem.
https://www.appliancepar...-wp389387-ap6008840.html
Usually the washer is pretty worn out by the time this part fails, but not always. you'll just have to weigh the age of the washer against the cost of the repair.
wilsonjiaho
#3 Posted : Tuesday, January 31, 2023 7:08:45 PM(UTC)
wilsonjiaho
Canada
have you tried other wash cycle?
Guest
#4 Posted : Wednesday, February 1, 2023 4:38:11 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
yes the problem happens withe very cycle and setting
wilsonjiaho
#5 Posted : Wednesday, February 1, 2023 6:03:28 PM(UTC)
wilsonjiaho
Canada
look at the back of the timer and see any burn or abnormal
Guest
#6 Posted : Wednesday, February 1, 2023 10:00:49 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
yes i checked the back of timer and all wires and connecting are looking great no burns or abnormalities
Guest
#7 Posted : Thursday, February 2, 2023 8:33:40 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
Just a guess but the timer may have some contact points sticking together (if it is an older design timer ) and there is not much chance of repair. A new timer is likely to be needed.
ThatGuy
#8 Posted : Thursday, February 2, 2023 2:36:47 PM(UTC)
ThatGuy
Groups: Expert
United States
That's not how the transmission works. The timer controls motor direction... forward and backward. Everything else is done inside the transmission... mechanically. One direction to agitate, the other to drain... pause... then spin.
Guest
#9 Posted : Thursday, February 2, 2023 3:04:19 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
is their a part that i would replace or is it better to replace the whole transmission? replacing transmission don't look like much work but kinda nervous about taking transmission apart to replace something inside of it due to all the seals that would have to be replaced
wilsonjiaho
#10 Posted : Thursday, February 2, 2023 7:20:03 PM(UTC)
wilsonjiaho
Canada
something is exciting the transmission to run continously. is there an electrical diagram?
2 Pages12>
