Bucket fills up with water to the top regardless of the setting. When spin cycle starts, bucket also fills up with water. Unit starts vibrating when in spin cycle? Is this a timer problem, water valve? Older unit. Worth repair?
Could be the water level switch, but check out the tube going from it to the tub. Clean it out and try things again, that may fix things at no cost!
If that does not help, try changing out the water pressure/level switch.
