| » Washer won't spin |
Model Number: LSR8433KQO Brand: Whirlpool Age: 1 - 5 years
Every function on the washer seems to work fine except it does not spin. The agitation seems to work well and pump seem to work fine. Don't hear any abnormal sounds. The timer seems to go thru the sequences just fine. I susupect either a gear house problem or a bad clutch. Must say I'm a novus . Please help?
Related Models |
Pull off the outer panel, the pump and motor. Inspect the coupling, if ok, turn the coupler on the tranny clockwise till the spin basket tries to turn. If very hard to turn with one hand, you either have dragging brake shoes, or something stuck in the tub. You can shine a light in the tub to check for something jammed there.
__________________
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 4 | 08-19-2009 06:32 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 7 | 03-05-2009 04:26 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
