jlm1969
#1 Posted : Friday, December 5, 2008 7:30:32 PM(UTC)
jlm1969
The softner dispenser is clogged and i need to clean it out. I have the top part off which holds fabric softner, and got a screw out from inside the agitator , but still cant get the top part off to clean it out.
magician59
#2 Posted : Monday, December 8, 2008 6:41:02 AM(UTC)
magician59
A common ingredient of most fabric softeners is made from animal fat or lard. It has a tendency to rot in hot and humid climates. Try this first: Get a bottle of Washer Magic (found in the laundry supply aisle in your supermarket). Follow the directions on the bottle, using the hottest water you can get in the machine. Unless you have an unusual build-up in your softener cup/agitator, this should save you a bit of work in removing/replacing the agitator cap.
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Maytag Washer shaking - badly (Washer Repair)
by chansman94 1/12/2023 6:47:51 AM(UTC)
