while i was repairing my dryer i knocked a wire loose blk/ red although i have a the wiring diagram i can not determine where it goes could someone give me some assistance thank you
You have posted on the washer forum.
If you will repost on the dryer forum someone may be able to help you. See if you can tell us the approximate location of the loose wire.
the red/blk wire is coming out of the harness that goes in to timer control scymatic says it controls water valve can not find water valve washer will not fill up
I am assuming that your wire connection has come off at the timer side. If you look at the sample wiring diagram on page 12 in the service manual it indicates that the red/black wire connects to T15 on the timer. http://frigidaireservicetips.com/pdfs/488_3.pdf
