Downstairs fridge stopped working over the weekend. Turned out start relay was bad. I replaced it with a 3n1 starter but do not have the wiring diagram. I have found the wiring diagram for an ET8CHKXKQ00 however it has a different compressor. I know which post is ground of the three and do not have an ohm meter to test resistance. Would all Whirpool compressors have Common on bottom, Run, left post and Start Right post? It was hooked up with White to Run and it ran and cooled for a few hours but then stopped, I could hear compressor start but then stop. Based on what I read the run and stop were backwards, switched them and it ran for a few mins and comp stopped. Unplugging and plugging back in and it would run a bit then stop.
Anyone have the wiring diagram for an ET1MTKXKQ00? or know how wires needs to go, Red to run and white to start?
Thanks in advance
