My ice maker seems to gradually overfill. This cause a large clump of ice buildup that prevent the ice maker from moving to dump the ice cubes. I suspect the dual fill valve is leaking a little water past the valve on the ice maker side. The water side works fine. Is this a reasonable diagnosis or should I check further? Thank you, Darrell
