My ice maker stopped working. I checked the dual solenoid valve and it is fine. I ordered a new ice maker but it doesn't work correctly either. It will only fill the ice mold if i manually turn the gear and then only once in a while. The ice maker i ordered is part 5303918277 recommended by your site. I just can't figure out what could be wrong. I also checked the door switch.please help. Thanks The complete mod.# is frs26zrgd3.
