Quit making ice, when I open door to the freezer the light blinks twice and pauses for a second and then blinks twice again. I've cleaned sensors to see if that would help but it didn't. Water comes out of the water dispenser on the front of the door so you can have a cold cup of water. I tried to conduct continuity test on ice level control board and water inlet valve but only shows how to perform test with 2 contacts, both of mine have 4 contacts so I'm unaware of how the test should be interperated. I also put water into the ice tray and it made ice with the water that I put in there but did nothing after that. Any help would be appreciated. Its easy to take parts off but may cost a small fortune to replace all of the possible problems. I'd like to narrow down the potential problem. Thanks again
