Hello Experts,
Recently our ice maker stopped making ice. I noticed that the grommet valve in the back of the fridge near the top was leaking water. I took that off and the feeder tube and it was frozen inside which I cleaned out. Next I took the ice maker itself out and noticed that the compartment that received the water was also frozen solid. I cleaned all of that out with warm water. Thinking that this was the issue, I put it all back together and went to bed. In the morning the grommet had fallen out and water was on the floor. I am stumped as to what would force it to fall out in this way. I ordered a new grommet from you guys, but I don't think this is the problem.
Thanks Stuart
