My ice maker has quit working. I pulled it out and let it dry out and re-installed it. It filled with water and dumped small cubes several times and would never dump any after the first several loads. I am looking at part AP2984633 but can't tell if it is my replacement. I don't have a door dispenser, just a slide out drawer for ice. I have two electrical plugs, one flat with three connectors and a second flat with two connectors. Is this the correct replacement. The only identifier on the ice maker on the front is IM # S 106 626667 S1.
What is the full model number on the model/serial tag of your refrigerator? Simply enter the full model number into the parts search box to find the correct one.
The model # is KSSS48FMX. The full picture of AP2984633 appears to show only one electrical connection. However the blow of parts to AP2984633 seems to show two electrical connectors. Which is correct for AP2984633?
