I got a water leak under the frig in the back below the ice/water solenoids. I took the line loose to the water dispenser in the door, at the solenoid, because it was dripping but it seems supple and to be OK. This line goes up and into the frig and connects to a plastic heat exchanger-I guess to keep the water cold. I'm thinking now it might be the solenoid feed line leaking and dripping onto this line. Everything is kind of jumbled in there and it's hard to see.
When I shut the water off to the frig the leak stops. It's a 14 years old unit Profile model 24 but it otherwise works OK.
Bakerout,
A model number would be a big help, but, Yes go with a new water valve assembly, if you have checked the connections and they are tight, and the tubing is not cracked or brittle. You did a good diagnosis, by turning the water supply off.
Good Luck and Thanks, :) :) :)
