rodey01
#1 Posted : Wednesday, December 22, 2021 5:20:31 AM(UTC)
rodey01
I have a water leak on the back upper right corner where the the blue and grey water lines enter the fridge for what I assume is the ice maker and water dispenser. Does not leak continually, I assume it does when water is dispensed. Looks like the leak is after it passes through into the back of the fridge, but it finds it’s way externally down the back side of the fridge. Any suggestions or tips for repair would be appreciated. Not sure f I just need a replacement line, or something internal fails. Thanks!
rodey01
#2 Posted : Wednesday, December 22, 2021 6:21:37 AM(UTC)
rodey01
After watching a video on your site, it appears the water is coming out of the gray line that feeds the ice maker, after it passes through the back of the fridge. Any suggestions on what I should replace is appreciated. No ice build up in ice maker area. Would it be worth replacing the line into the ice maker? Replace the ice maker? Replace nothing and gamble?
Edited by user Wednesday, December 22, 2021 3:36:41 PM(UTC)  | Reason: Not specified
