The ice maker stopped working. The fill tube is not clogged. It is not cycling. I disconnected the water line to the ice maker, and no water is coming out. the water on the door if fine. Could it be a valve that is stuck not letting the water through? I hear no sound from the ice maker at all. What to do?
