The icemaker is getting water and making ice but will not dump the ice. Holding the switch down manually does NOT cycle the dump arms either. Which of the devices - F15 micro switch, 67 switch kit or F7 MOTOR-ICE MAKER SVO do I need? Also on this icemaker the ice crucher works intermittently dumping whole ice cubes several at a time - Is this the F45 the solenoid asssembly or just a poor design by Frigidaire? It did NOT used to do this.
