rpetransky
#1 Posted : Monday, December 29, 2008 4:41:46 PM(UTC)
rpetransky
I just purchased the add-on ice maker kit for my Frigidaire FRT8B5EWC refrigerator. I have everything hooked up and the water is turned on, but it doesn't look like the water valve is working? I double checked that the water lines were connected correctly. I'm not hearing the valve engage. Any ideas on how I can troubleshoot the valve? I poured some water into the ice tray and it ejected ice cubes this afternoon so I know that part of the kit works. I'm thinking that it may be a power issue or the coil on the solenoid valve is dead. Can anybody tell me if there should be constant voltage coming off of the plug that attaches to the valve? Any help is greatly appreciated!
TechnicianBrian
#2 Posted : Monday, December 29, 2008 7:11:51 PM(UTC)
TechnicianBrian
The valve only has voltage to it when the icemaker is calling for water. Hook a multimeter up to the two wires to the valve and start a harvest cycle by turning the gear on the end of the icemaker. It will only take a click or two and it should take off by itself. Keep and eye on the meter to see if 120vac shows up. If it does, then the valve must be dead. If no voltage, then it's time to check the icemaker.
rpetransky
#3 Posted : Tuesday, December 30, 2008 11:35:45 AM(UTC)
rpetransky
Thanks for the info. I popped the front cover off of the ice maker with my screwdriver and gave a good turn on the small gear counterclockwise. It cycled through and I heard the valve open, but it was real quick, not enough to fill the tray so I adjusted the water fill setting and things appear to be working. It would be nice if the manufacturer included this information in the installation instructions. Thanks for your help!
TechnicianBrian
#4 Posted : Tuesday, December 30, 2008 3:23:01 PM(UTC)
TechnicianBrian
Glad I could help.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
