DARBYSCD
#1 Posted : Monday, August 18, 2008 6:27:23 AM(UTC)
DARBYSCD
Water And Ice Dispenser Seems To Be A Problem. The Water Works Some Of The Times, But The Ice Does Not Dispense. When Trying To Dispense The Water Or Ice The Light On The Dispenser Goes Very Dim. Also The Main Wire On The Back Of The Fridge Keeps Getting Loose. I Have Dumped The Ice Out Twice But It Still Does Not Work. Please Help Me.
abadfish66
#2 Posted : Monday, August 18, 2008 6:41:12 AM(UTC)
abadfish66
Can you please explain what wire keeps getting loose, and can you provide the serial#
DARBYSCD
#3 Posted : Monday, August 18, 2008 8:52:21 AM(UTC)
DARBYSCD
Its The Wires That The Fan And Compressor Are On. Serial# SH217269.
WE TIE WRAPPED THE WIRES TO KEEP THEM TOGETHER. ANY HELP WILL BE APPRECIATED.
DARBYSCD
#4 Posted : Tuesday, August 19, 2008 10:42:21 AM(UTC)
DARBYSCD
Water And Ice Dispenser Seems To Be A Problem. The Water Works Some Of The Times, But The Ice Does Not Dispense. When Trying To Dispense The Water Or Ice The Light On The Dispenser Goes Very Dim. When we try to use the dispenser when the motor is runnung it stops running for a while then it starts back up. Also The Main Wire On The Back Of The Fridge Keeps Getting Loose. It is the wire that the fan and condenser are plugged into. We have tie wrapped the wires and it seems to be working for now. I Have Dumped The Ice Out Twice But It Still Does Not Work. Please Help Me.
abadfish66
#5 Posted : Tuesday, August 19, 2008 10:50:25 AM(UTC)
abadfish66
Your main board needs to be replaced WR55x10552. If it is 0-3 years old the repair is free, 3-5 years is $100, and over 5 years $300. You can call 1-800-432-2737 to set up service from GE. Just FYI they wont tell you on the phone about this program, but the tech that comes out will have all info. Or you can order the part here for about $86.00
abadfish66
#6 Posted : Tuesday, August 19, 2008 11:02:11 AM(UTC)
abadfish66
DARBYSCD
#7 Posted : Tuesday, August 19, 2008 11:06:27 AM(UTC)
DARBYSCD
Thank You So Much.
abadfish66
#8 Posted : Tuesday, August 19, 2008 11:14:03 AM(UTC)
abadfish66
No problem, glad to help
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
