Randy2828
#1 Posted : Saturday, August 9, 2008 5:22:33 AM(UTC)
Randy2828
Water leaks out the front of the refrigerator. The drain hose in the bottom of the refrig is not blocked.
#2 Posted : Saturday, August 9, 2008 9:52:25 PM(UTC)
Randy,
Most likely the problem is a clogged and/or frozen drain hole under the evaporator inside the freezer.
Here are the break down diagrams for the Amana refrigerator Model NT19G7
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
LG frig LFD25860ST water leak (Refrigerator & Freezer Repair)
by tnzookeeper 1/24/2019 12:31:01 PM(UTC)
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 3:20:07 PM(UTC)
