i have 2 refrigerators one is ge other is maytag. i pluged them upom outside to see i they were gonna work they came on and run for about 20 minutes and then shut off no part of the compressor unit will come back on. is this the overload switch?:confused:
You may have tripped the ground fault outlet.
