melindadunn3
#1 Posted : Saturday, February 13, 2010 12:02:46 PM(UTC)
melindadunn3
used the dryer it got real hot then tryed to use it again and it want start but can hear the timer running
#2 Posted : Sunday, February 14, 2010 12:47:28 AM(UTC)
Here are your parts, includes a wiring diagram
Wiring information replacement parts for CROSLEY CDE22B6V Dryer - Ele | AppliancePartsPros.com
I believe the wiring diagram is mis-labelled. The HI TEMP THERMOSTAT at the bottom of the wiring diagram should be just THERMOSTAT. It is the main or cycling thermostat.
Sounds like you blew the THERMAL FUSE NON RESETTABLE re: "used the dryer it got real hot"
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Odds are that the thermal fuse on the heater is blown.
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system, I would do this even if the heating element is grounded.
Check/clean the blower wheel, would also do this.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
melindadunn3
#3 Posted : Monday, February 15, 2010 8:20:13 AM(UTC)
melindadunn3
how do i check the thermal fuse?
melindadunn3
#4 Posted : Monday, February 15, 2010 8:59:52 AM(UTC)
melindadunn3
how do i check thermal fuse
#5 Posted : Monday, February 15, 2010 9:13:47 AM(UTC)
Unplug the machine
Disconnect one wire from the thermal fuse.
Measure it with a meter, should be 0 ohms.
melindadunn3
#6 Posted : Monday, February 15, 2010 9:24:37 AM(UTC)
melindadunn3
ok i checked it it was 0
melindadunn3
#7 Posted : Monday, February 15, 2010 9:25:22 AM(UTC)
melindadunn3
what do i do now?
melindadunn3
#8 Posted : Monday, February 15, 2010 11:12:45 AM(UTC)
melindadunn3
ok i changed out my thermal fuse . that was the problem .thank you so much and GOD bless ya
Dryer Want Start (Dryer Repair)
by wmageesr 10/22/2011 12:42:34 PM(UTC)
G E Dryer want start (Dryer Repair)
by drdavid 10/18/2011 11:32:49 AM(UTC)
dryer want start (Dryer Repair)
by melindadunn3 2/15/2010 8:01:57 AM(UTC)
RCA Dryer want start (Dryer Repair)
by bookerfam 10/6/2009 7:02:51 AM(UTC)
Dryer want start but moter hums (Dryer Repair)
by Dallas Adkins 3/3/2008 8:12:03 AM(UTC)
