dafense
#1 Posted : Wednesday, February 10, 2010 6:13:16 PM(UTC)
dafense
Our dryer will not start, though light inside works and timer ticks. There was a large lint build up at the last use. I took off the back panel and the fuse looks fine (just a black strip, nothing burned) and i cannot tell if the other thermostats are blown, as I do not know what to look for, and they do not look to be resettable. I am not sure what to do/replace/test. Any help would be appreciated
#2 Posted : Thursday, February 11, 2010 5:31:19 AM(UTC)
Replacement parts for WHIRLPOOL GEQ8858EQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406699.pdf
You cannot tell if the fuse is blown just by looking at it. Note it is Item 7 is Section 3.
Part number: AP3132867
Unplug the unit and remove one wire from it and check it with a meter, should be 0 ohms.
Jiggery pokery method is:
Unplug the unit.
Remove both wires from the fuse and short them together.
Tape them so they cannot short to anything else.
Plug it in and give it a try,
If blown replace it ASAP as it is a critical safety device.
Prevents lint fires which can turn into house fires.
Be sure to clean the blower wheel and clean/check your vent system as this is the most common causes of it blowing.
dafense
#3 Posted : Thursday, February 11, 2010 9:01:46 AM(UTC)
dafense
yep that did it - its the fuse - thanks a million
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Whirlpool Dryer will not start, have power "sensing light is on" Replaced both thermi (Dryer Repair)
by joanu 11/21/2013 6:32:09 AM(UTC)
Whirlpool dryer will not start (Dryer Repair)
by vaughn quern 11/26/2012 9:52:02 AM(UTC)
by vaughn quern 11/26/2012 9:44:09 AM(UTC)
whirlpool dryer will not start (Dryer Repair)
by mikeshard 3/29/2012 8:49:17 PM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
by Newglide 1/12/2011 6:54:14 PM(UTC)
by mbryans 1/7/2010 12:31:19 PM(UTC)
by rsqmedic8 7/26/2009 7:43:08 AM(UTC)
by bratsinc4 2/4/2009 6:05:06 PM(UTC)
