2 Pages12>
c33341
#1 Posted : Friday, March 11, 2011 9:47:28 AM(UTC)
c33341
My Whirlpool start button will not start the dryer.
I have removed the lint chute & cleaned it. I checked the continuity on the Thermal Fuse & it is ok.
Should I check the continuity on the Thermostat, Internal-Bias Part number AP3045874 ? It has the four wires attached to it.
Can the Relay behind the start switch be bad? Part number AP2974634, also can I check the continuity on this part? It has three prongs to it.
If it could be this relay how do I remove it?
If you have any other ideas I am open to anything.
Thanks for your help.
C33341
Jeff / APP Team
#2 Posted : Friday, March 11, 2011 12:39:32 PM(UTC)
Jeff / APP Team
Hello c33341,
Have you checked the door switch to see if it is working properly? Thanks. AP3132865
Cabinet parts replacement parts for WHIRLPOOL LGQ9858PG0 29``GAS DRYER | AppliancePartsPros.com
c33341
#3 Posted : Friday, March 11, 2011 12:45:18 PM(UTC)
c33341
I read in one of these blogs, If two of these things are ok it would not be the door switch. I read so many of them I cannot tell you the one I read. But with this information my switch should be ok.
Jeff / APP Team
#4 Posted : Friday, March 11, 2011 12:47:36 PM(UTC)
Jeff / APP Team
You will need to test the door switch and see if it is good. Check and see if the plastic piece is broke off inside the door. Hope this helps.
c33341
#5 Posted : Friday, March 11, 2011 12:56:09 PM(UTC)
c33341
I will give that a try. How do I get inside the door?
Thanks Jeff
Jeff / APP Team
#6 Posted : Friday, March 11, 2011 12:58:47 PM(UTC)
Jeff / APP Team
There are two clips under the top of the dryer that will need to be released, along with two screws under the lint filter that will need to be removed, to access the door switch. Thanks.
c33341
#7 Posted : Friday, March 11, 2011 1:05:20 PM(UTC)
c33341
Thanks for your information, but I have to go to dinner tonight, I will try this when I return later tonight.
Jeff thanks again for your Help
c33341
#8 Posted : Friday, March 11, 2011 1:22:02 PM(UTC)
c33341
Jeff I held my wife up to go to dinner & checked the door switch, the plastic is intact. I will check the continuity in the door switch when I return.
c33341
#9 Posted : Saturday, March 12, 2011 8:37:37 AM(UTC)
c33341
The continuity of the door switch is good, and so is the cycling thermostat. The only thing I have left is the start relay, and the thermostat on the burner. I will check them next.
c33341
#10 Posted : Saturday, March 12, 2011 12:06:47 PM(UTC)
c33341
I have checked the door switch, and it is good.
I have checked the Thermostat Internal-bias Part no. AP 3045874 and it is good.
I checked the T-Stat, High limit Part AP 3084674 and it has a digital ohm reading of 0.2, and I do not know if this good or bad.
I checked the Thermal cut off Part AP 3176214 and it has a digital reading of 0.3 and I do not know if it is good or bad.
The Thermal Fuse, Thermostat Internal-bias, and the door switch was checked at a local Parts store with an analog meter. These three check good.
I double checked the Thermal Fuse by taping the two wires together to see if the dryer would start, it did not start.
I checked the Relay Part AP 2974634 and the digital reading is 1804. I do not know if this is good or bad.
I am familiar with an Analog Meter, and not with a Digital Meter.
Any help would be appreciated. Thank you.
2 Pages12>
