haroldlm
#1 Posted : Tuesday, December 29, 2009 7:03:09 PM(UTC)
haroldlm
Got codes E31 and E5E. Which wants me to change out pressure sensor, which I did. Also changed out control board. Machine still gives same codes and will not start. Checked wireing and it's ok also. Whats wrong?:confused:
sidfink43
#2 Posted : Wednesday, December 30, 2009 3:08:25 PM(UTC)
sidfink43
Front loaders with microprocessor control have a built in diagnostic. When the control unit does not get a signal that the system is operating it shuts down and give a "communications" error. Unfortunately the error code does not give any hint of the problem, so you end up replacing components on spec.
If you are certain the wiring is not compromised then replacing the motor control unit is the next step, but this cannot be guaranteed to fix it.
Here is a service manual for your machine.
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
GE Cafe dishwasher will not start (Dishwasher Repair)
by Guest 5/18/2023 11:11:14 PM(UTC)
Samsung dishwasher will not start wash cycle (Dishwasher Repair)
by relentless85 8/12/2016 5:57:33 PM(UTC)
Dishwasher Will not start (Dishwasher Repair)
by BajaScout 10/31/2015 12:54:52 PM(UTC)
kitchen aide dishwasher will not start (Dishwasher Repair)
by Edwin L Davis 4/26/2015 6:02:45 PM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
washer will not start filling/timer suspected (Washer Repair)
by rossgray 3/2/2015 10:32:38 AM(UTC)
by bigbuckkie 12/19/2014 4:28:48 PM(UTC)
Kitchenaid dishwasher will not start and makes humming noise (Dishwasher Repair)
by jbritton@evisionsys.com 9/28/2014 9:08:26 AM(UTC)
Frigidaire Affinity Washer Will Not Start or Display Diagnostic Codes (Washer Repair)
by pwmin 8/5/2014 7:40:09 PM(UTC)
Neptune washer will not start (Washer Repair)
Belarus Wilsonwelch 5/2/2014 10:17:36 AM(UTC)
Maytag dishwasher will not start (Dishwasher Repair)
by timwhitten 3/24/2014 2:15:09 PM(UTC)
washer will not start if medium load selected (Washer Repair)
by Brucek 6/8/2013 11:35:04 AM(UTC)
Diswasher will not start cycle (Dishwasher Repair)
by gcooker 4/28/2013 8:51:03 AM(UTC)
GE front load washer will not start (Washer Repair)
by LisaHall 1/23/2013 2:53:39 PM(UTC)
GE Washer will not start (Washer Repair)
by neco187 1/12/2013 6:40:54 PM(UTC)
