jwilliams20019
#1 Posted : Wednesday, December 23, 2009 11:55:41 AM(UTC)
jwilliams20019
I turned the Oven on the other day an saw a small spark, then noticed that the Bake element does not heat up. I purchased the new bottom (bake) element and installed it but the bottom element still does not work. I read somewhere that I might need replace the control unit but not sure what part that is?
Any help with this is greatly appreciated. Thank You
maqsoodmahboob
#2 Posted : Wednesday, December 23, 2009 12:24:03 PM(UTC)
maqsoodmahboob
I have similar problem. My model # is cplef398aca four burners glass top. Two burners on right side will heat only on high; other temp. selections will not work. Also that small spark will come up even if the oven is not in use but is plugged in. Recently there was an unrelated Safety Recall on this model and all four Control Elements and one Control Electrical were replaed but it has not resolved the problem. I called a few repair shops; they did not call back. Either the job is too small or too complicated. If you get it fixed, please let me know also. Thanks
Frigidare gas oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 10:34:40 AM(UTC)
Frigidare affinity dryer model FAQE7077KB0 (Dryer Repair)
by Guest 4/16/2022 12:54:55 AM(UTC)
frigidare icemaker issue (General Talk)
by corvairbob 12/8/2021 10:54:37 AM(UTC)
Frigidare GLEF379DBD (Oven Repair (including Ranges and Cooktops))
by jperrico 12/24/2020 7:19:55 AM(UTC)
Frigidare wall oven not heating (Oven Repair (including Ranges and Cooktops))
by mlhayespa 8/29/2020 12:13:52 PM(UTC)
frigidare microwave fgmv175qfa blows fuse (Microwave Repair)
by bmaskiell 3/27/2020 8:23:39 AM(UTC)
Frigidare FEX831CS0 (Dryer Repair)
by stealthpaws 7/6/2019 5:10:40 AM(UTC)
Frigidare FFID2423RS4B - Blackened Latch Connector (Dishwasher Repair)
by KAW 5/26/2019 6:14:53 AM(UTC)
frigidare ATFB6000FS0 washing machine (Washer Repair)
by booknails 1/2/2019 1:38:27 PM(UTC)
Housing wheel loose on frigidare dryer (Dryer Repair)
by Kcsrugs 10/29/2016 9:17:23 AM(UTC)
frigidare laundry center (Washer Repair)
by makenna15 8/11/2016 2:15:42 PM(UTC)
Frigidare flashing "4" (Refrigerator & Freezer Repair)
by mikie0607 1/13/2016 11:23:07 AM(UTC)
frigidare to whirlpool conversion wiring (Refrigerator & Freezer Repair)
by chuck44l 12/4/2014 9:26:51 AM(UTC)
Replace upper spray arm, Frigidare dishwasher (Dishwasher Repair)
by StephanieZ 6/20/2014 9:57:30 AM(UTC)
Frigidare stackable timer not advancing (Washer Repair)
by aford89 3/12/2014 8:06:17 AM(UTC)
