Groups ready for retrieval: Registered
My Washer Works Fine Accept The Agitator Will Not Move In The Wash Cycle Could It Be A Belt And How Do I Access The Unit To Find Out Or See All The Parts Inside
If it will spin but won’t agitate the first thing I would look at is the agitator coupling. Attempt to turn the agitator by hand. It shouldn’t turn easily and if it does the agitator coupling is stripped out. To replace it remove the agitator by lifting straight up. Once off you will see the coupling (it may be called an air bell on parts breakdown). A 7/16 bolt holds it on. If that doesn’t seem to be the problem post back and we will go from there. Clothes Washer Repair Guide
