DConway0005
#1 Posted : Thursday, March 16, 2017 3:40:22 PM(UTC)
DConway0005
dryer doesn't start, checked both door and start switches for continuity. checked all three thermostat components for continuity. all these parts had continuity. help please!
brobriffin
#2 Posted : Thursday, March 16, 2017 4:28:00 PM(UTC)
brobriffin
Man
United States
One more switch to check is the belt switch. If the belt breaks or comes off the tensioner pulley the switch will open and the machine won't start.
Watch the video with this link to access that switch.
GE WD21X10261 Interlock Switch - AppliancePartsPros.com
If the belt is broken here is your part #
GE WE12M29 Dryer Drum Drive Belt - AppliancePartsPros.com
DConway0005
#3 Posted : Thursday, March 16, 2017 4:40:59 PM(UTC)
DConway0005
thanks a lot! just disconnected it and checked its continuity and it didn't buzz. the dryer was also full of lint, I used an air duster and if I change this belt switch, will I have to change anyting else, or should that do the trick?
brobriffin
#4 Posted : Thursday, March 16, 2017 4:52:46 PM(UTC)
brobriffin
Man
United States
If that switch is bad then that should be all! However check the belt for wear and tear while your in there.
DConway0005
#5 Posted : Thursday, March 16, 2017 7:00:45 PM(UTC)
DConway0005
I was wrong, I double checked the switch once I pulled it out, didn't realize there was a button (hence "switch") the belt switch had continuity. I'm back to square one. all switches and thermostats including the 3 on the back and the one beside the motor all had continuity and I still don't know what the problem is. could it be the motor?
brobriffin
#6 Posted : Sunday, March 19, 2017 4:51:11 AM(UTC)
brobriffin
Man
United States
When you push the start switch does the motor buzz or hum?
Also have you checked voltage across the incoming lines?
With the dryer plugged in, using your Multi-meter set to voltage, check across L1 and L2 for 240 volts. If this is true then check from each Line to neutral to see if they are equal 120 volts give or take a couple volts. If any or these tests fail reset the circuit breaker and try the test again.
If one Line is 130 or above and the other is 110 or below then you possibly have a loose neutral at your electric panel (call electrician to repair if so)
The motor will not start with low incoming voltage on Line 1.
DConway0005
#7 Posted : Sunday, March 19, 2017 12:45:53 PM(UTC)
DConway0005
The motor doesn't make any sound. I hear nothing, just the faint sound of the start switch. The voltages are all correct. Could one of the components be bad even though it has continuity? I shook the thermostats (the one by the motor) and it had something rattling in it. It was the only one I shook though, so I have no clue if the other thermostats rattled when shook?
brobriffin
#8 Posted : Sunday, March 19, 2017 6:30:50 PM(UTC)
brobriffin
Man
United States
Only the thermal fuse, the door switch and the belt switch would prevent the dryer from starting. If the "push to start" button is working properly then the only other alternatives are;
bad contacts in the timer or
a bad motor
I don't think the motor is it... so check the following
look at the wiring schematic and see what line sends power to the start switch then to the motor and check (with your multi-meter) if there is continuity from the incoming power (likely the red line connection) to the line connection leading to the motor. It will take some sleuthing of the wiring diagram to figure out which connections on the back of the timer to check.
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by Matt18 11/26/2013 9:56:49 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
by Rogscott 4/13/2012 4:34:09 PM(UTC)
