bigerdady1
#1 Posted : Wednesday, May 6, 2015 12:26:07 PM(UTC)
bigerdady1
OK I noticed water leaking out of outer tub onto the Transmission area or kind of right center when looking in from the back after opening the back.
figured it was the tub seal. got the inner tube and everything removed except outer tub. is the only way to R & R the seal is to remove the motor , transmission case and all the other parts from the underside and dose it in fact sound like the tub seal. Ive check all the hoses and pump and everything else I can think of...And if you agree do you have part numbers for the seal as well as the drive hub , nut and block as well as the 6 screws.
Thanks Don
Jeff / APP Team
#2 Posted : Thursday, May 7, 2015 4:57:40 AM(UTC)
Jeff / APP Team
Hello Bigerdady1. Yes, you have to remove the gear case to replace the seal and it does sound like the seal will need to be replaced on the unit. Part number: AP4567772
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 8/29/2023 9:04:08 PM(UTC)
Maytag Bravos washer Tub Seal (Washer Repair)
by Guest 3/3/2023 5:31:44 PM(UTC)
maytag bravos washer motor spins but not pulley (Dishwasher Repair)
by brokenwasherman 3/12/2022 7:46:04 AM(UTC)
Maytag Bravos washer won’t spin - weird noise (Washer Repair)
by Helpwithmywasher 12/25/2019 2:01:44 AM(UTC)
Maytag Bravos Washer (Washer Repair)
by tverleye 6/12/2017 3:50:43 PM(UTC)
Help! Problem Installing New Bearings in Maytag Bravos Washer (Washer Repair)
by Twang 4/10/2017 3:26:22 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
Maytag Bravos Washer Clicking (Washer Repair)
by machouse36 9/10/2016 4:07:14 AM(UTC)
Maytag bravos washer not stopping .. (Washer Repair)
by wasco22 2/7/2016 8:24:52 PM(UTC)
Maytag Bravos washer just hums even when powered off (Washer Repair)
by guytonmomma 1/18/2014 2:16:24 AM(UTC)
Maytag Bravos washer lid won't unlock (Washer Repair)
by JC-rookie 9/5/2013 7:49:48 AM(UTC)
by TreyWaltman 3/28/2013 8:42:50 AM(UTC)
maytag bravos washer (Washer Repair)
by MIKIMAC1952 3/27/2013 7:10:18 AM(UTC)
by 1beatlesfan 7/9/2012 5:46:27 PM(UTC)
by donnadel123@bellsouth.net 8/9/2011 6:22:30 PM(UTC)
