souljoe
#1 Posted : Thursday, November 20, 2014 4:48:08 PM(UTC)
souljoe
The machine will not drain completely all the time. I bought a new pump from APP.com and installed it with the same results (Lid Switch tested good). On the first cycle after installing the pump the machine did the same thing. It stopped spinning and left about 6 inches of water in the tub. Bewildered I just happened to put my elbow on the lid and the thing started up again and completed the spin cycle and drained all the water. After it was done I closed the lid and gently pushed on the lid and I could here the switch click with the pressure. My question is can the switch be adjusted? Has the lid somehow gotten bent? During a normal cycle it starts spinning but my guess is the vibration is somehow disengaging the switch and the slight pressure I put on the lid remakes it. It has got to be either the switch, the lid or the thing on the lid that contacts the switch. Any ideas? Don't want to rebuild this thing part by part. Thanks
fairbank56
#2 Posted : Thursday, November 20, 2014 5:57:09 PM(UTC)
fairbank56
Groups: Expert
Take the lid switch out and have a good look at it. This type is very prone to coming apart. It can be glued back together or cinched with a small tie wrap. If it does not appear to be coming apart, the internal contacts may be failing so just replace the switch.
Whirlpool 285671 Lid Switch Assembly - AppliancePartsPros.com
Eric
How to remove terminals from Kenmore washer lid switch connector (Washer Repair)
by NCRX 8/25/2015 2:14:33 PM(UTC)
Washer Lid Switch (part #3949247) (Washer Repair)
by YZT 12/8/2014 5:55:02 AM(UTC)
Maytag washer lid switch (Washer Repair)
by Anki 2/25/2014 4:13:32 PM(UTC)
fuse on replacement washer lid switch assembly (Washer Repair)
by flmikee 12/25/2013 7:02:54 AM(UTC)
maytag washer lid switch (Washer Repair)
by krissoto 6/1/2013 5:22:37 PM(UTC)
Kenmore Washer Lid Switch - model number on replacement rubbed out (Washer Repair)
by duplex 5/9/2013 7:21:06 AM(UTC)
Washer lid switch wires (Washer Repair)
by bonnie2003 9/15/2011 4:01:01 PM(UTC)
by xyz334 6/9/2011 11:52:40 AM(UTC)
Washer lid switch (Washer Repair)
by xyzabc 5/25/2011 8:32:52 PM(UTC)
by professor007 4/15/2011 5:25:10 PM(UTC)
Whirlpool washer lid switch assembly (Washer Repair)
by Mailman83 6/24/2010 4:54:39 PM(UTC)
by repairtodoer 2/11/2010 12:28:53 PM(UTC)
Stackable washer lid switch replacement (Washer Repair)
by tmealy 8/18/2009 10:22:32 AM(UTC)
by FayeP 7/27/2009 12:59:51 PM(UTC)
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 7/27/2009 5:50:25 AM(UTC)
