flmikee
#1 Posted : Wednesday, December 25, 2013 7:02:54 AM(UTC)
flmikee
Ordered and received a new lid switch assembly (part # 22001682). The assembly shows it is for a 4 amp fuse, my original is a 1 amp fuse. Is this an upgrade or the wrong part? Thanks
fairbank56
#2 Posted : Wednesday, December 25, 2013 7:08:43 AM(UTC)
fairbank56
Groups: Expert
1 amp is the standard size. The label says 4 amp max. The fuse isn't really there to protect any wiring, it's there to blow in the event the lid switch gets stuck closed. With blown fuse, washer will not fill so is basically rendered inoperable til you fix the switch.
Eric
