dnell
#1 Posted : Tuesday, August 26, 2014 7:21:16 PM(UTC)
dnell
my whirlpool dryer stop heating, so I checked the element. I noticed that the thermostat attached to the element was burned out. I replaced the heating element and the thermostat that is attached to the heating element but still no heat. what should I check next to find out why I'm not getting heat or what should I check to find out what caused the thermostat to burn out.
#2 Posted : Wednesday, August 27, 2014 1:00:14 AM(UTC)
Parts for Whirlpool LER4634EQ1 Dryer - AppliancePartsPros.com
I would start by checking the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Was it the thermal cut-off on the heater assembly that you replaced or just the hi-limit thermostat or both?
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
by Teresay 6/11/2013 6:40:08 PM(UTC)
Dryer won't heat up (Dryer Repair)
by ford4wd08 6/11/2013 9:42:58 AM(UTC)
frigidaire dryer won't heat up (Dryer Repair)
by wilde1537 5/6/2013 10:27:04 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
by d burns 5/17/2012 12:18:14 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Dryer won't heat up to dry clothes (Dryer Repair)
by tdeai 7/21/2011 3:55:49 PM(UTC)
by krisr 2/8/2011 2:52:24 PM(UTC)
Heating Element on Roper Dryer won't heat up (Dryer Repair)
by c grass 11/23/2010 5:26:01 AM(UTC)
by WW47 7/29/2010 1:07:03 PM(UTC)
GE Electric Dryer won't heat up (Dryer Repair)
by lizt 12/27/2009 12:07:30 PM(UTC)
