Pat Shea
#1 Posted : Sunday, August 24, 2014 12:26:55 PM(UTC)
Pat Shea
My washer started making a sqeeking/whistling noise while in the spin mode and then disapears when it gets up to speed. It doesn't make a noise in the wash mode only the spin mode. One time it also had a burnt smell while in the spin mode. I had a belt replaced about a year ago could it possbly need a new belt again?
sidfink43
#2 Posted : Sunday, August 24, 2014 6:16:24 PM(UTC)
sidfink43
Take off the front panel and operate the machine. First check to see if the belt is slipping, and if so it may be damaged in which case you can replace it.
If the noise is coming from base it may be damper pads, this part here
Part number: AP4024203
If the noise is coming from the transmission it could be the brakes are not releasing or that the transmission is failing. Note, it is very dangerous to work on these brakes without the proper tools and instructions as they are under a high pressure spring which can cause serious injury.
If you do decide to tackle it see if you can obtain a service manual on line for a small charge.
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
GE GTWS8655D0MC washer noise (Washer Repair)
by Guest 12/7/2021 12:52:56 PM(UTC)
Washer Noise ONLY when agitating (Washer Repair)
by akak01000101 10/4/2018 9:27:54 AM(UTC)
loud washer noise on high rpm spin (Washer Repair)
by Tradar57 1/15/2018 6:33:27 PM(UTC)
Whirlpool Washer Noise (Washer Repair)
by cheriemarie78 9/5/2017 8:04:41 AM(UTC)
Washer noise (banging) spin cycle (Washer Repair)
by rtdwest1 5/11/2017 12:18:47 PM(UTC)
Whirlpool washer noise during braking (Washer Repair)
by Mommeeu 8/6/2016 9:50:02 AM(UTC)
GE washer noise during agitation (Washer Repair)
by nikkibee 5/9/2016 10:54:51 AM(UTC)
GE Dishwasher noise (Dishwasher Repair)
by bhorvath7666 9/13/2015 7:29:12 AM(UTC)
Cabrio Washer Noise (Washer Repair)
by Waltmanj 7/24/2015 9:36:26 AM(UTC)
Washer noises (Washer Repair)
by Deniseforry 3/3/2015 4:32:37 PM(UTC)
dishwasher noise while washing (Dishwasher Repair)
by mpickell 2/27/2015 7:10:27 PM(UTC)
GE Washer Noise (Washer Repair)
by CaptainChris 9/16/2014 12:33:21 PM(UTC)
Washer noise (Washer Repair)
by Tank47 8/2/2014 11:26:44 AM(UTC)
