randall729
#1 Posted : Saturday, November 16, 2013 12:40:13 PM(UTC)
randall729
I would gladly appreciate any pointers on this situation. This is a lp gas stove. The burners work fine. The broiler works fine. The bake igniter
won't glow. I checked with a 120V test light at the connector to the
igniter. There was no voltage and therefore the igniter will not work.
I am not sure what to do next or where to check for voltage and how to get power to the bake igniter. Any suggestions please. Thank you.
Appliance Ninja
#2 Posted : Saturday, November 16, 2013 1:12:23 PM(UTC)
Appliance Ninja
On the igniter, there are two leads. One goes to the gas valve and one goes to the oven control. Turn the oven on and test from the wire that goes to the control and ground (any metal surface). Do you read 120 VAC?
randall729
#3 Posted : Saturday, November 16, 2013 1:37:02 PM(UTC)
randall729
attn: appl. ninja will try this and get back with you. thank you.
randall729
#4 Posted : Saturday, November 16, 2013 1:48:48 PM(UTC)
randall729
I am not getting any volts by doing this.
Appliance Ninja
#5 Posted : Saturday, November 16, 2013 2:28:18 PM(UTC)
Appliance Ninja
If you read no voltage, the oven control is faulty and will need to be replaced. The correct control for your model is available at the link below.
Whirlpool 5701M509-60 Cntrl-Elec - AppliancePartsPros.com
Maytag oven model mgs5870adw shuts off intermittently (Oven Repair (including Ranges and Cooktops))
by Guest 10/28/2021 1:24:33 PM(UTC)
Maytag oven/range model# mer5755qaw control board (Oven Repair (including Ranges and Cooktops))
by g3ride69 1/24/2021 3:22:05 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Maytag Oven Top Element (Oven Repair (including Ranges and Cooktops))
by AppFixer 8/2/2016 4:35:04 PM(UTC)
Maytag oven with F1 code (Oven Repair (including Ranges and Cooktops))
by Bwhite 6/28/2015 10:46:23 AM(UTC)
Maytag oven won't clean (Oven Repair (including Ranges and Cooktops))
by cyclemom 6/18/2015 6:28:23 PM(UTC)
Maytag oven (Oven Repair (including Ranges and Cooktops))
by SaraScript 4/25/2015 3:14:57 PM(UTC)
by SaraScript 4/25/2015 3:13:57 PM(UTC)
by SaraScript 4/25/2015 3:13:03 PM(UTC)
Maytag ovens stop heating while starting (Oven Repair (including Ranges and Cooktops))
by Marcelo127 11/30/2014 6:45:52 AM(UTC)
maytag oven control panel wiring (Oven Repair (including Ranges and Cooktops))
by cmkowals 12/12/2013 1:19:45 PM(UTC)
Electrical nightmare Maytag oven (Oven Repair (including Ranges and Cooktops))
by randall729 11/17/2013 5:54:50 PM(UTC)
Maytag oven will not bake ... HELP ME!!! (Oven Repair (including Ranges and Cooktops))
by Tarzan95959 11/10/2013 2:21:54 PM(UTC)
“Causes” when burner does not work on Maytag oven (Oven Repair (including Ranges and Cooktops))
by bcalfee 9/14/2013 3:15:53 PM(UTC)
Gas Maytag Oven giving me heating trouble (Oven Repair (including Ranges and Cooktops))
by sevykor 6/12/2013 10:59:36 AM(UTC)
