I do not get any spark for the burners to lite but the oven still works. Is it possible for the spark module to be bad even if the oven ignites?
There are two different types of ignition used in this range. The oven used a flat hot surface igniter while there is a spark ignition for the surface burners. Most likely the problem with you range is a bad spark module. - The spark module Part number: AP2126192
