Papa B
#1 Posted : Wednesday, October 2, 2013 2:16:32 AM(UTC)
Papa B
My Matyag Legacy Series washer model#SAV515DAWW was making bearing noise and leaking water from the tub seal. I just installed a new Triple Lip Seal/Bearing Kit, and the lower main Bearing, suprisingly everything went smooth... until I when I went to cycle it, it sounded like a machine gun. The noise is coming from transmission pulley jumping up and down. It seams to be just on the spin cycle as it was agitating at first now it doesn't even do that??? any help would be appreciated as I have about $200 in parts...hope I didn't damage the transmission pulling the lower bearing off as I heard a loud pop, not sure if it was the bearing breaking loose or something else?
PS: A new transmission was installed about 4-5 yrs. ago under warranty
HumboldtRepairMan
#2 Posted : Wednesday, October 2, 2013 5:15:11 PM(UTC)
HumboldtRepairMan
Call a tech in because obviously you weren't able to diagnose or fix the problem or assemble it back together correctly.
GE washer making loud noise during spin cycle (Washer Repair)
by vinnyb 1/23/2016 10:58:06 AM(UTC)
Washer making loud noises every time it switches cycle (Washer Repair)
by Geetanjalidogra 10/9/2013 4:11:51 PM(UTC)
GE front load washer making loud noise during spin cycle (Washer Repair)
by wendyyx33 11/29/2012 8:41:29 AM(UTC)
maytag washer making loud noises (Oven Repair (including Ranges and Cooktops))
by bmitchell89 3/2/2011 10:40:44 AM(UTC)
Washer making loud noise (Washer Repair)
by John from NT 3/2/2010 6:17:43 AM(UTC)
