phebert
#1 Posted : Saturday, October 10, 2009 1:54:45 PM(UTC)
phebert
Dish washer working fine. Next load ran thru cycle ok, when opened dry soap at bottom and dishes still dirty. Checked other cycles rise, heavy duty, ect. same issue -- no water. Checked supply line & hose all ok. Any info on common concerns? Diagram on how it works? Electrical problem? How about a valve or screen?
I tried search feature nothing on this model but found no info.
Thanks in advance for any info.
#2 Posted : Sunday, October 11, 2009 3:07:45 AM(UTC)
Replacement parts for WHIRLPOOL SUD5000KQ0 | AppliancePartsPros.com
Could be one of the following:
Overflow/float. Check that the float is not stuck in the up position. Switch should be closed, check it with a meter.
Valve filter screen. Remove the valve and check it. If it is clogged up clean it. Do not remove it as it is there to keep crud out of the valve, which could hold it open and cause a flood. Also a good idea to drain some water out of your hot water tank as crud collects in the bottom of the tank.
Valve itself. Check that it is getting voltage when it should (120 volts). If yes and the filter screen is clean the valve is shot.
Controller. If the valve is not getting voltage and the overflow/float switch is closed, could be the contacts in the timer are shot.
Bad wire. Check the wires from the valve to the control for continuity.
Cannot find tech info on this unit but perhaps the following will help.
http://www.applianceaid.com/dishwash.html
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
