fourspots
#1 Posted : Friday, May 3, 2013 8:51:25 AM(UTC)
fourspots
I have a problem with the Agitator not working. While trying to remove the agitator to inspect the grooves to see if they are damaged, I'm unable to remove the agitator. Once I unscrew the cap, there is a screw at top of agitator. I was told to place a belt underneath the agitator and give a tug and the agitator will pop out. I believe that I must remove the bolt at the top. The nut is flush with the top of the agitator. There is no way to reach the bolt because it is flush with agitator. Do you know how to remove agitator on this old stackable washer/dryer combo?
Frustrated
fairbank56
#2 Posted : Friday, May 3, 2013 9:11:37 AM(UTC)
fairbank56
Groups: Expert
Use a 1/2 inch socket wrench with extension to remove the bolt.
Eric
fourspots
#3 Posted : Friday, May 3, 2013 9:40:38 AM(UTC)
fourspots
Hello Eric,
Is it possible that the agitator can be pushed down far enough to get a socket wrench on the 1/2 inch bolt? I can see the bolt but it is flush with the top of the agitator and it is countersunk into the agitator. Their is no way to get a socket onto the bolt unless the agitator will go down 1/4-1/2 an inch.
Rick
fairbank56
#4 Posted : Friday, May 3, 2013 11:50:01 AM(UTC)
fairbank56
Groups: Expert
This washer is made by Electrolux for GE. I have a service manual for the model that has the fabric softener dispenser on top of the agitator and I now see that yours does not have this so the top of your agitator is different. The only thing I can think of is to use a wire with a hook on it to try and fish under the agitator to see if some clothing is caught under there that may have caused the agitator to work it's way up into the bolt head. A clear photo of your agitator/bolt may be useful, I can ask around.
Eric
GE Stacked washer dryer - Agitator Removal (Dryer Repair)
by Guest 5/31/2021 10:26:51 AM(UTC)
Kenmore 20022011 agitator removal (Washer Repair)
by d0ugparker 3/18/2015 8:46:07 AM(UTC)
kenmore agitator removal - bolt turns but won't come out (Washer Repair)
by kimkim 3/2/2015 9:25:47 AM(UTC)
Amana agitator removal (Washer Repair)
by Max Strasser 8/6/2014 11:09:33 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Agitator removal (Washer Repair)
by kenziegranny 2/12/2012 7:36:24 AM(UTC)
by cutthroattrout1 1/4/2012 1:26:48 AM(UTC)
agitator removal steps; is washer lid removal required (Washer Repair)
by tomdrzich@hotmail.com 8/11/2011 5:36:48 AM(UTC)
by sabado 1/14/2011 6:22:25 PM(UTC)
by rpflynnsr 12/21/2010 11:13:40 AM(UTC)
by engcash 10/20/2010 11:01:54 AM(UTC)
Hotpoint agitator removal (Washer Repair)
by dleatherbu 10/10/2010 10:40:20 AM(UTC)
1980s whirlpool agitator removal (Washer Repair)
by billhuber 10/4/2010 5:20:06 PM(UTC)
by BARDOME' 9/6/2010 11:36:27 AM(UTC)
agitator removal help (Washer Repair)
by anomaly 6/14/2010 12:07:44 PM(UTC)
