cutthroattrout1
#1 Posted : Wednesday, January 4, 2012 1:26:48 AM(UTC)
cutthroattrout1
So I am attemping to remove the Agitator on our Kenmore. After Reomving the Fabric Softener Dispensor and the Dust Cap and Seal I expected to find a hex bolt thatr I could remove with a 7/16 socket. Looking down inside the top of the Agitator cavity I could only see the end of what looked like a threaded stud. It did not appear to be a bolt with the head broken off. (which was my first thought). Is there another type of removal process for this model of washer?
I tried to tug upward (pretty hard) on the agitator in case it really was a broken agitator mounting bolt. The top of the agitator did move upward a small amount before I hit the mechanical limit.
Please tell me if this is a unique model.
#2 Posted : Wednesday, January 4, 2012 3:15:09 AM(UTC)
You need a deep well socket to get the stud out.
cutthroattrout1
#3 Posted : Wednesday, January 4, 2012 6:44:56 PM(UTC)
cutthroattrout1
Day two now. I called a local appliance repair shop to get my answer. Under the dust cover there was a 1/2 inch square feature that was just as deep. It is designed to accept a 1/2 in drive extension without a socket. After loosening this part that has spring under it, I was able to remove this part and then the top half of the agitator. That exposed a hex nut stud that I was able to remove with a 14mm deep well socket.
Thanks for the reply richappy. I did need some additional help to get deep enough to apply your comment.
GE Stacked washer dryer - Agitator Removal (Dryer Repair)
by Guest 5/31/2021 10:26:51 AM(UTC)
Kenmore 20022011 agitator removal (Washer Repair)
by d0ugparker 3/18/2015 8:46:07 AM(UTC)
kenmore agitator removal - bolt turns but won't come out (Washer Repair)
by kimkim 3/2/2015 9:25:47 AM(UTC)
Amana agitator removal (Washer Repair)
by Max Strasser 8/6/2014 11:09:33 AM(UTC)
Agitator Removal (Washer Repair)
by fourspots 5/3/2013 8:51:25 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Agitator removal (Washer Repair)
by kenziegranny 2/12/2012 7:36:24 AM(UTC)
agitator removal steps; is washer lid removal required (Washer Repair)
by tomdrzich@hotmail.com 8/11/2011 5:36:48 AM(UTC)
by sabado 1/14/2011 6:22:25 PM(UTC)
by rpflynnsr 12/21/2010 11:13:40 AM(UTC)
by engcash 10/20/2010 11:01:54 AM(UTC)
Hotpoint agitator removal (Washer Repair)
by dleatherbu 10/10/2010 10:40:20 AM(UTC)
1980s whirlpool agitator removal (Washer Repair)
by billhuber 10/4/2010 5:20:06 PM(UTC)
by BARDOME' 9/6/2010 11:36:27 AM(UTC)
agitator removal help (Washer Repair)
by anomaly 6/14/2010 12:07:44 PM(UTC)
