gblotter
#1 Posted : Friday, February 8, 2013 8:23:32 PM(UTC)
gblotter
My GE front-loader washer advances through the cycles, but will not drain or spin at the end. During the spin cycle, I sometimes see it agitating as it does during the wash cycle.
I have read other threads here about similar problem with the Frigidaire version of this washer.
Recommended solution was check/replace door lock - see http://forum.appliancepartspros...fills-water-no-spin.html
Recommended solution was check/replace motor/speed control unit - see http://forum.appliancepartspros...12-washer-wont-spin.html
Recommended solution was check/replace pump - see http://forum.appliancepartspros...nt-loader-wont-spin.html
Any help appreciated - thanks.
gblotter
#2 Posted : Friday, February 8, 2013 9:24:03 PM(UTC)
gblotter
Problem fixed - see solution below.
Apparently the washer will not enter the spin cycle unless/until the water has drained from the drum.
I removed the lower panel to check the drain line and the pump. The drain line was clear, but the pump was clogged with a fabric softener dryer sheet (I could feel it when sticking my finger up inside the pump). After dislodging and removing the dryer sheet, everything seems to function normally now. Wahoo!
