just_chillin38
#1 Posted : Thursday, December 27, 2012 12:12:34 PM(UTC)
just_chillin38
HelpPlease!!!!!!
[FONT="Calibri","sans-serif"]Washer does everything but agitate. You can hear a grinding sounding but theagitator will not move.:eek: I have a Westinghouse Model MWX433REW0 Washer.[/FONT]
Simon / APP Team
#2 Posted : Thursday, December 27, 2012 12:34:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unscrew the agitator cap, remove the screw and check through the center opening if the transmission shaft is moving back and forth in agitation.
If it does - pull out the agitator Part number: 5303937150
and check the splines inside and hub splines
Part number: 134418700
If not, then most likely it's a bad transmission
Here are the breakdown diagrams and Universal / Multiflex (frigidaire) Washer-5995285052 Motor / Tub parts for Frigidaire MWX433REW0 - AppliancePartsPros.com
Post the results.
Simon.
just_chillin38
#3 Posted : Friday, December 28, 2012 2:45:07 PM(UTC)
just_chillin38
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
I've removed the agitator, and the splines look fine. The shift will only turn in one direction. It will agitate if there are no clothes in the machine, once clothes are added then it will not agitate.
Simon / APP Team
#4 Posted : Friday, December 28, 2012 3:32:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if you can hold the transmission shaft with you hands.
If you do - then it's bad tranny.
Simon.
How to remove agitator on GE GTWP1800D0WW (Washer Repair)
by CCC1620 1/24/2015 10:40:44 AM(UTC)
How to remove agitator from GE washer (Washer Repair)
by jthrrt 1/1/2013 4:43:23 PM(UTC)
How to Remove Agitator (Washer Repair)
by this_is_nascar 6/11/2012 8:32:07 AM(UTC)
how to remove Agitator on Frigidaire (Washer Repair)
by vinster 10/4/2011 11:46:19 AM(UTC)
How to remove agitator assembly (Washer Repair)
by BylerB 3/6/2010 5:41:41 AM(UTC)
How to remove agitator (Washer Repair)
by salem70123 10/5/2009 6:42:02 PM(UTC)
by OleRon 9/21/2009 8:35:00 AM(UTC)
How to remove agitator assy (Washer Repair)
by ddjclark 6/3/2009 4:34:25 PM(UTC)
How to remove agitator on newer GE washer (Washer Repair)
by lba 12/29/2008 8:26:41 AM(UTC)
How to remove agitator? (Washer Repair)
by Dobbsey 10/15/2008 1:03:15 PM(UTC)
