Thank you for your help.
My wife mentioned that on her Duet Washer she started getting an F6 error. I checked the CCU and it appeared all the wires were connected okay. I went the the "wires" "plug" attached to the motor and as one of the internet responses suggested I checked out the ohms between pins 1-2, 2-3, 1-3 and 4-5. I believe I got 6.7 on the first three readings and 119 on 4-5. The internet blog suggested if I get those reading I order MCU AP3861856. I want to be reasonablly sure this is what I should do vs. ordering the CCU. Can you confirm or make other suggestions.
Thanks,
JS...
