I recently replaced the broiler element because the old element was not heating. After putting it all back together the new element doesn't heat either. When I turn the dial to broil I hear a click but the element doesn't heat up. Any advice on my next step would be appreciated.
Groups: APP Team
Hi. Using the multimeter check if there is 240VAC to the range. With broil on check for 240VAC L2 at the block and BRL at the control board. No 240VAc - replace the control board Part number: WB27X10311
Thank you. Post the results. Simon.
