Broiler element does not heat. How does one remove the element and/or test to make sure that it is the element that is bad. Unscrewing the mounting screws does not enable the element to be removed. It does not just plug in to the back of the oven.
Not sure if this is your exact model but it may help. Parts breadkown - Model GSC30CVWC-01Nat
