kmenmart
#1 Posted : Monday, July 16, 2012 4:46:31 PM(UTC)
kmenmart
my washer's control knob that allows you to which between which kind of loads i have(white, colored, cotton, ect.) will not work anymore. its like it doesnt have a connection sometimes. as i am a mother of three i need to get this probllem resovled as soon as possible. is there a part that i need to replace or what?
sidfink43
#2 Posted : Tuesday, July 17, 2012 5:23:25 PM(UTC)
sidfink43
It is possible there is a problem with the knob, but more likely the problem is with the control panel.
You are going to have to take off the top, then remove the dispenser, remove the screw inside the dispenser recess and the other four screws that hold the control panel to the cover, and then release the tabs that hold the control panel to the cover.
If the problem is with the control panel I suggest getting a new machine. It is an expensive part and while these models are great when they work, this particular model is somewhat unreliable and very difficult and expensive to diagnose and repair.
Sorry not to have better news.
GE Glasstop stove burner control knob (Oven Repair (including Ranges and Cooktops))
by Guest 9/17/2023 5:25:35 AM(UTC)
Where can I find a control knob to fit a 5mm D shaft potentiometer? (Dryer Repair)
by Guest 6/29/2022 11:20:48 AM(UTC)
Kenmore 970-C80032-00 dryer Control Knob (Dryer Repair)
by Guest 5/30/2022 8:16:19 AM(UTC)
change dacor oven from touch pad to manual control knobs (Oven Repair (including Ranges and Cooktops))
by prop 1/15/2019 11:04:14 AM(UTC)
how to remove washer control knob (Washer Repair)
by Mrs.fixit 7/30/2015 11:43:56 AM(UTC)
Control knob (Washer Repair)
by glendot 5/24/2015 3:07:55 PM(UTC)
Dryer Control Knob Shaft (Dryer Repair)
by eogrady 12/28/2014 7:17:05 AM(UTC)
Range control knob broken (Oven Repair (including Ranges and Cooktops))
by boonjh 1/25/2014 3:16:45 PM(UTC)
Kitchenaid gas range power burner control knob doesn't turn past Lite (Oven Repair (including Ranges and Cooktops))
by dathinker 9/9/2013 9:31:18 AM(UTC)
Control Knob broke off during a move (Washer Repair)
by mattndi1991 8/4/2013 4:14:06 AM(UTC)
removing control knob on washer (Washer Repair)
by Jme1408 7/27/2013 8:51:53 PM(UTC)
Need Control Knobs (Oven Repair (including Ranges and Cooktops))
by ninaszlosberg 6/17/2013 4:13:45 PM(UTC)
Jenn-Air 5 burner control knobs are sparking (Oven Repair (including Ranges and Cooktops))
by HHStang 3/10/2013 6:55:34 PM(UTC)
Burner Control Knob (Oven Repair (including Ranges and Cooktops))
by Kdog12 7/17/2012 3:19:40 PM(UTC)
How do I remove sliding temp control knobs? (Refrigerator & Freezer Repair)
by Markzub 6/20/2012 6:32:24 PM(UTC)
